Home » Sponsored » Pi Speakers » Measuring Doppler Distortion
Measuring Doppler Distortion [message #48760] Tue, 31 January 2006 07:36 Go to next message
bgavin is currently offline  bgavin
Much is mentioned about Doppler distortion in direct radiator subs.
Q: can Doppler distortion be measured with LMS or ?? into a quantifiable figure for comparative purposes?
Re: Measuring Doppler Distortion [message #48762 is a reply to message #48760] Tue, 31 January 2006 09:25 Go to previous message
Measuring intermodulation distortion is a little more complex than measuring harmonic distortion. The Doppler effect is the phenomenon that makes a train have higher pitch when it is coming towards you, and drift off to a lower pitch when going away. It is related to cone movement, and is a function of excursion and frequency. So while it's an easy concept to grasp, it's a little trickier to quantify by measurement. The waveshape itself changes, modified by the movement of the cone.
Previous Topic: 7pi
Next Topic: 3 Pi Theater With 8" Eminence Beta Midrange
Current Time: Sun Nov 08 00:33:17 CST 2026
