Home » Sponsored » Pi Speakers » Anybody with plans and circuit for 12" based 3 ways?
Anybody with plans and circuit for 12" based 3 ways? [message #48621] Sun, 15 January 2006 13:58 Go to next message
braddog100 is currently offline  braddog100
I have some 12" Cerwin Vegas'. I know they are not the best, but I would like to put them to use. I also have a pair of Axon T1S Shielded Dome tweeters. Zn ~ 8ohm; 2000 - 20,000; Pn ~ 50W;
Lm ~ 90 db; Re 6,4ohm; fs ~ 1550 Hz;
b ~ 1.7mm; Sd ~ 6.7 cm2;
I would like suggestions for some quality mids to go with this.
I have seen some 4ohm setups for reasons unkown to me, But I would prefere 8ohm since I use alot of tube gear. I could bi-amp since I have a good solid state unit. Would be open to several opinions.
Looking for Box design, circuit, mid range suggestions. I could also concider other tweeters.
I thank you very much,
Brad
Re: Anybody with plans and circuit for 12" based 3 ways? [message #48624 is a reply to message #48621] Sun, 15 January 2006 20:48 Go to previous messageGo to next message
Sorry, but you'll need a lot more information to make a good loudspeaker design. I might humbly suggest that the amount of time required to obtain the information you'll need to do a good job would probably be more than the drivers are worth. Then again, the learning experience is worth a lot, so it might be interesting for you on that level. But if you're looking for a good quality build without a lot of enfgineering, you might want to build from plans that have already been designed and tested.
Re: Anybody with plans and circuit for 12" based 3 ways? [message #48626 is a reply to message #48624] Mon, 16 January 2006 00:38 Go to previous message
Yep, that is true.
Thanks, Buddy
Previous Topic: Is mixing 'n matching cabs a bad idea ?
Next Topic: Seven pi corner
Current Time: Fri Oct 16 18:52:38 CDT 2026
