Home » Sponsored » Pi Speakers » Hy
Hy [message #48453] Fri, 23 December 2005 08:00 Go to next message
j.luis cruz . is currently offline  j.luis cruz .
Hy Wayne.. How does the 7 Pi audiophile sound with respect to the 7 Pi theater..thanks
Re: Hy [message #48455 is a reply to message #48453] Fri, 23 December 2005 09:20 Go to previous messageGo to next message
The Audiophile series sounds cleaner, and I think a little more powerful sounding too.
Re: Hy [message #48458 is a reply to message #48455] Fri, 23 December 2005 15:29 Go to previous messageGo to next message
Hy..Wayne thanks for your answer ,but I have some doubts you say that the 7 pi audiophile sound more powerfull and I see that the magnum rules but regarding the mid and tweeter section is the same in both systems .does the crossover Wayne count for the difference in sound in from the midhorn and tweeter. once again thanks
Re: Hy [message #48459 is a reply to message #48458] Sat, 24 December 2005 08:33 Go to previous message
The Magnum used in the Audiophile Series seven π has a shorting ring which makes it cleaner and its electro-mechanical parameters make it hit harder on the low notes in a relatively small box. The Theater Series seven π is nice too, and the alignment is perfect for corner loading, but the speaker is a little larger and the woofer does not have a shorting ring.
Previous Topic: Crossover for Alpha-8 / APT
Next Topic: PSD 2002 xover freq
Current Time: Sat Oct 31 15:38:10 CDT 2026
