Home » Sponsored » Pi Speakers » Stage Four & SET?
Stage Four & SET? [message #48213] Thu, 17 November 2005 04:38 Go to next message
peppennino is currently offline  peppennino
Hi Wayne!
Stage 4 series can be suitable with a SET tube amp (300B JEL type). Which are the most important tonal differences with the Theater 4?
I mostly listen to orchestral music, contemporary & classical, & world music.Can you send me (if they're suitable) the Stage four plans to closely consider them?
Thanks
Vincenzo
You've got mail! [message #48219 is a reply to message #48213] Thu, 17 November 2005 11:09 Go to previous messageGo to next message
The Stage four π speaker sounds a little fuller in the bass, which makes it better suited for half-space to quarter-space placement, eighth-space is too much. It is also a bit harder to drive for some SET amps, but others sound fabulous. It depends as much on the output circuit configuration as the output tube. The Theater four π speaker is very rich sounding, works with any amplifier and is best placed in quarter-space or eighth-space.
Re: You've got mail! [message #48221 is a reply to message #48219] Thu, 17 November 2005 11:51 Go to previous message
Thanks
Previous Topic: Stage 4's are finally done! Any placement tips, tweaks, or ??
Next Topic: alpha or beta
Current Time: Mon Nov 02 07:34:18 CST 2026
