| Woofer Tester 2 [message #48184] |
Mon, 14 November 2005 11:36  |
Spinjack
Messages: 100 Registered: May 2009
Viscount |
Anyone know anything about the Dayton Woofer Tester 2 (part # 390-802) sold by Parts Express? Does it work? Is it worth the money?
| Re: Woofer Tester 2 [message #48189 is a reply to message #48187] |
Mon, 14 November 2005 16:14   |
spkrman57
Messages: 522 Registered: May 2009
Illuminati (1st Degree) |
I use a cabinet of known proportions to measure Vas with. Much easier for me than all them weights on the cone. I have found the WT2 to be pretty accurate for a inexpensive device. Ron
| Re: Woofer Tester 2 [message #48190 is a reply to message #48185] |
Mon, 14 November 2005 16:24   |
Spinjack
Viscount |
Yeah, I like your method. Except I don't have a signal generator, an oscilloscope, or a selaed box of know volume that can accept a wide range of drivers. I think I've found some signal generator software, but the tester seemed to be the quick and easy way (Yoda would be soooo disappointed). Also, getting the Vas values seemed to require quite a bit of through away work. Is there another way to calculate Vas without the need to build a sealed box of known volume, including driver volume?
| Re: Woofer Tester 2 [message #48192 is a reply to message #48190] |
Mon, 14 November 2005 16:59  |
I think that little tester is probably a pretty good deal. I just have had all the equipment, the scopes, meters, signal generators and what-not since the 1970's, so I'm comfortable using them. Oscilloscopes and meters aren't really all that great for acoustic measurements, but they're good for electrical measurements. They're really all you need to measure electro-mechanical parameters.You can measure Vas using a sealed box or added mass. You won't need a box for the added mass method. I used to approximate compliance with another method, but both the sealed box and added mass measurements are more accurate.
