Home » Sponsored » Pi Speakers » Bass Driver for horn
Bass Driver for horn [message #47209] Tue, 28 June 2005 10:45 Go to next message
Tom A. is currently offline  Tom A.
Wayne, I am considering building an all horn system, and your seven π design looks about right for my application (home theater). I have a choice between two drivers right now, both 15" high power PA speakers. The spec's of driver---------------------------------------------------- driver A: Le=.73 Re=3.97 30-2,500 hz response Fs=38.9Hz Vas=6.0cu.ft. Qms=4.06 Qes=.39 Qts=.36 SPL=96.5 Xmax=2.3mm---------------------------------------------------------driver B: Le=.70 Re=5.2 40-4000 response Fs=44.2 Vas=6.42 cu.ft. Qms=9.2 Qes=.38 Qts=.36 SPL=100 db/m Xmax=2.5mm---------------------------------------------------------- with the Qms, Qes, and Fs being different enough, is there a clear winner between the two? My target SPL after horn loading is 104-105 db/m and I need a HF crossover point of about 300Hz. Does the lower Qms of driver A result in a smoother response curve?.........Thanks, James
Re: Bass Driver for horn [message #47210 is a reply to message #47209] Tue, 28 June 2005 11:22 Go to previous messageGo to next message
Both of these drivers will work very well in seven π cabinets. I'll send plans if you're interested.
Re: Bass Driver for horn [message #47215 is a reply to message #47210] Tue, 28 June 2005 22:23 Go to previous messageGo to next message
Thanks Wayne, please send me the seven π and the six π plans if you would. James
You've got mail! [message #47219 is a reply to message #47215] Wed, 29 June 2005 11:19 Go to previous message
Previous Topic: 7pi and 8pi plans
Next Topic: Perfect Subwoofer for 4 pi
Current Time: Mon Nov 16 00:05:27 CST 2026
