4Pi -> 7Pi Plan, making the 7Pi's shorter [message #47142] |
Thu, 16 June 2005 21:23 |
swett
Messages: 47 Registered: May 2009
Baron |
I have the drivers for 4Pi pro's and I want to make it easy to upgrade to 7Pi's in the future, by just changing the crossover, turning the woofer cabinet around, and adding a midhorn. But I have a 44.5" total height restriction, so I'd need to make the bass cabinets with that in mind. My tweeter horn will be 5" tall, and the midhorn is 14" tall, leaving me with 25.5" for the bass cabinet. The plans specify a taller cabinet, so is that enough? Obviously I can make the cabinet deeper to make the cabinet volume work out, but will the horn chamber work correctly? Also, would the woofer height remain the same distance from the floor? The other option is to just buy the Delta 10's and build the midrange horns into the cornerhorn cabinet. I'm not sure what I'd do about the extra width at the front, but I'm sure I could figure something out. Maybe I could flare the whole cabinet slightly so it was 26" wide at the front? What do you think?
Just like the old 7Pi's? [message #47144 is a reply to message #47143] |
Fri, 17 June 2005 01:02 |
swett
Baron |
That sounds like the old 7Pi's I saw, which was pretty much my plan. How much should I move the woofer up the cabinet? My main concern was about changing the height of the cabinets and whether that will negatively effect the cornerhorn response? -Ian
π Cornerhorns - a brief history [message #47145 is a reply to message #47144] |
Fri, 17 June 2005 01:41 |
Messages: 18678 Registered: January 2001
The basic seven π cabinet has been unchanged since inception in the 1970's. It's a very simple design, with its main feature being that the woofer radiates from the apex of the room's corner. The corner is used as a large CD horn that provides 9dB DI all by itself, and no passageways or labyrinthine cabinetry is required. That makes the cabinet easy to build, and it isn't prone to panel vibrations. It's easy to brace and there aren't a lot of complex pieces that might develop buzzes or panel resonances.
The best results are generally from cabinets having slightly overdamped ported alignments, but some rooms sound good with loudspeaker alignments having less damping. Very tightly sealed rooms might sound good using critically damped sealed alignments, but most framed drywall homes are somewhat lossy, and I prefer an overdamped vented alignment. But the point is that the bass bin design hasn't changed at all since the seventies. I like it very much, because it offers a lot from a very simple package.
seven π cornerhorn
The woofers used and the midrange and tweeter configurations have gone through several incremental changes. The first models used various Eminence and JBL Pro woofers, much like are still used today. My favorite early model had a JBL 2205 woofer and used JBL 2105 mids. The idea was to use the woofer up to the point where the walls transitioned from launch boundaries to reflectors, and crossover at that point. This also limited the number of standing wave modes that would be present in the cabinet interior.
I found that reflected midrange gave an ambience that sounded good too, so I experimented with putting midrange drivers in the rear in some models, and even ran the system as a two-way for a while. The current model uses a 90x40 midhorn that crosses over from the woofer before the walls act as reflectors, so there is very little reflected enegry. It sounds very natural and large.
What I've found is that each of these models shared a common trait of creating a very uniform reverberent field. This is a result of using sound sources that are all coming from the room's corner apex, and confined by the walls. None of the sound sources becomes more narrow than 90º except at the very highest frequencies, so the tonal balance throughout the room is good.
The main difference between versions, beyond the quality and tonal differences in the drivers themselves, is that some models generated more early reflections in the midrange. This creates a complex field that tends to give a sense of spaciousness. Those creating less early reflections sound a little more intimate, more like a close mic'ed recording. But in each case, the tonal balance is uniform throughout the room, and the basic character of the various models of π cornerhorn loudspeakers is similar in many respects.
