Home » Sponsored » Pi Speakers » JBL 2226H 2 - way design for a beginner?
JBL 2226H 2 - way design for a beginner? [message #47040] Fri, 03 June 2005 19:17 Go to next message
Fredrik is currently offline  Fredrik
I have got 2 off 2226H' and want to build a 2 way speaker for my large living room. (600x900cm)
What do you reccomend for a beginner with no testing equiptment but with a good ear?
Do I need to incorporate an extra super tweeter as well, to end up with a frequenzy range that is not too compromized?
I am planning to use a computerized router to cut the cabinets if I can find some good drawings.
You've got mail! [message #47043 is a reply to message #47040] Fri, 03 June 2005 23:34 Go to previous message
The Pro four π is a two-way loudspeaker using a JBL 2226H and a JBL 2426H. You can substitute the Eminence PSD2002 tweeter if you wish.
There's a review of the Pro four π on the π Speakers website. A lot has been written about it in this forum too, so you might search through the archives.
Previous Topic: Question about this active crossover?
Next Topic: Finished with S.E.X., what's next?
Current Time: Sat Oct 24 10:30:34 CDT 2026
