Home » Sponsored » Pi Speakers » Here's a 15" wooferer with great specs for $172
Here's a 15" wooferer with great specs for $172 [message #47005] Wed, 01 June 2005 18:41 Go to next message
Can you tell the PE catalog came? Fs 38, SPL 99, QTS .28
Re: Here's a 15" wooferer with great specs for $172 [message #47007 is a reply to message #47005] Wed, 01 June 2005 22:30 Go to previous messageGo to next message
I heard those in Earl Geddes DI matched two-ways and they sounded nice to me. The electro-mechanical specs make it a drop-in replacement for a JBL 2226, so I expect it would work very well in the Pro four π loudspeaker.
They did well in his 4-way comparison [message #47010 is a reply to message #47007] Thu, 02 June 2005 10:21 Go to previous messageGo to next message
swett is currently offline  swett
In Earl's 4-way comparison, the B&C drivers beat out the TAD drivers, though by an almost insignificant margin.
Someone should try them in a Pi speaker and tell us how they sound. They might make for a more affordable pro.
-Ian
Flux stabilized woofers [message #47011 is a reply to message #47010] Thu, 02 June 2005 10:48 Go to previous messageGo to next message
I prefer the JBL 2226, but it's twice as expensive. For the cost, I think the B&C driver is good. The Eminence Magnum 15HO is a nice part too, but can't be used in a DI matched two-way because it rolls off too soon.
Have you listened to everything? [message #47012 is a reply to message #47011] Thu, 02 June 2005 10:57 Go to previous messageGo to next message
Have you listened to just about every driver under the sun? I assumed you'd never heard the B&C, though I don't know why I assumed that.
Thanks for your thoughts, though.
-Ian
Re: Have you listened to everything? [message #47013 is a reply to message #47012] Thu, 02 June 2005 11:51 Go to previous message
I appreciate your comments on the B&C woofer. There are plenty of drivers I haven't heard, but this one happens to be one I have. It's a pretty good part and I think it sounds good.
Previous Topic: Wayne, 8 pi plans
Next Topic: Should I build Pi's?
Current Time: Sun Apr 28 07:29:04 CDT 2024
