Home » Sponsored » Pi Speakers » H290 Horn flare vs JBL 2345
H290 Horn flare vs JBL 2345 [message #46981] Mon, 30 May 2005 05:26 Go to next message
Paul Holland is currently offline  Paul Holland
Hi folks,
Is the 800 hz jbl 2345 40 x 90 metal horn an equivalent horn to the eminence H290?
It would be used on top of an eight pi, with psd:2002.
Would the crossover need modification?
I just like the vintage look for the eight pi, and there may be a pair available locally.
regards,
Paul,
Sydney.
Re: H290 Horn flare vs JBL 2345 [message #46982 is a reply to message #46981] Mon, 30 May 2005 10:32 Go to previous messageGo to next message
The H290 is a small horn to be used above 1kHz. Since crossover is at 1.6kHz, it's just fine. But it is a smaller horn.
Re: Don't forget the Peavey CH-3 [message #46986 is a reply to message #46982] Mon, 30 May 2005 13:54 Go to previous messageGo to next message
Little heard of lately and too large for some cabinets but good sounding. The material is soft so be careful with tools. I used them in my Theatre 4's bought from a Wayne-friend store in OK.
Re: Don't forget the Peavey CH-3 [message #46987 is a reply to message #46986] Mon, 30 May 2005 17:32 Go to previous messageGo to next message
Yes, that one is still my favorite. I wish they moulded them in one piece because it would look better, but the two piece design doesn't hurt the sound at all.
Thanks for your responses, guys. (nt) [message #46988 is a reply to message #46981] Tue, 31 May 2005 03:50 Go to previous messageGo to next message
re: jbl 2345, H290, Peavey CH3.
Re: Don't forget the Peavey CH-3 [message #46990 is a reply to message #46987] Tue, 31 May 2005 12:47 Go to previous messageGo to next message
Crazy Dave is currently offline  Crazy Dave
Hi Waye,
Have you ever tried the current Peavy 1" compression driver? People have reported that it is a good one.
Dave
Re: Don't forget the Peavey CH-3 [message #46991 is a reply to message #46990] Tue, 31 May 2005 14:25 Go to previous message
No, I haven't tried it. Peavey has really made some good products in the last decade or so though. I'll bet it's a pretty good part.
Previous Topic: Speaker recommendations
Next Topic: Front loaded horn
Current Time: Wed Nov 04 11:41:20 CST 2026
