Home » Sponsored » Pi Speakers » Seven Pi base questions
Seven Pi base questions [message #46512] Sat, 19 March 2005 09:25 Go to next message
Dean Kukral is currently offline  Dean Kukral
I am getting ready to build the bass for the Seven Pi. I would like to know if the 2226 should be mounted internally (there is a gasket to facilitate this) or externally? Also, if I mount it externally, should I rout a ridge for it to sit in, so that the driver does not stand proud of the box, and should I use the gasket on the back side?
Also, does the box need additional bracing?
TIA,
Dean
Re: Seven Pi base questions [message #46513 is a reply to message #46512] Sat, 19 March 2005 09:50 Go to previous messageGo to next message
Mount it externally. That makes driver mounting a snap. You can route it flush if you'd like. As for bracing, the top and sides are solid but the front and back panels need bracing. Brace them well, at least put a cross brace in every 18". If the panel doesn't sound like a solid block of wood when you tap it, then you need additional bracing.
Thanks! (nt) [message #46514 is a reply to message #46513] Sat, 19 March 2005 15:49 Go to previous messageGo to next message
How do you do a "no text" message?
"This space intentionally left blank." [message #46515 is a reply to message #46514] Sat, 19 March 2005 17:31 Go to previous message
To make a blank message, press the space bar in the message field.
Previous Topic: 2 pi plans, please.
Next Topic: Crossover parts upgrades
Current Time: Fri May 17 14:53:35 CDT 2024
