Home » Sponsored » Pi Speakers » Pi components in Cornwall cabinet?
Pi components in Cornwall cabinet? [message #46247] Fri, 04 February 2005 21:22 Go to next message
cootcraig is currently offline  cootcraig
Greetings,
I've come across a pair of Klipsch Cornwall cabinets
with no components. Is there a Pi kit that would work
with these? Other suggestions on how to use the cabinets
would be welcome as well.
Re: Pi components in Cornwall cabinet? [message #46253 is a reply to message #46247] Sat, 05 February 2005 07:59 Go to previous messageGo to next message
The Cornwall used an Eminence-made woofer called the K33, internal Eminence part number 15162. It has the following specs:
Fts 34.46 Hz
Mms 78.59 g/m/s
Cms 0.2714 mm/N
Rms 2.3037 ns/M
Vas 10.65 ft3
Re 3.39 ohms
Le 0.96 mH
Qms 7.39
Qes 0.410
Qts 0.390
Xmax 8.20mm
BL 11.88
EBP 84.4
eff 2.91%
Sens 96dB
Max Pwr 150rms
The Cornwall cabinet is about 7ft3 and tuned to ~35Hz. So you could do pretty well with an Omega 15 or Magnum 15HO. Either one would be a big step up for not much more money than the stock replacement. As for the midrange and tweeter, you could perhaps find those on eBay. The midrange is a K55 and the tweeter is a K77.
Alternatively, you could make your own midrange and drive it with a small cone driver like the Alpha 6 and crossover to a PSD2002 on an H290 horn flare. Or you might even shoehorn in the midhorn I use, which would span the entire width of the speaker between the woofer and tweeter, and fill in the vertical space between them too. Naturally, either of these options will require some cabinet modifications.
Stage 4 PI Kit as 2-way? [message #46259 is a reply to message #46253] Sat, 05 February 2005 13:10 Go to previous messageGo to next message
Would the Stage 4 PI Kit 2-way work then?
With some cabinet mods to mount the H290.
Re: Stage 4 PI Kit as 2-way? [message #46260 is a reply to message #46259] Sat, 05 February 2005 17:11 Go to previous message
Certainly, you could convert to a two-way and use the Stage four π kit. Or if you wanted to keep it a three-way, get the Stage seven π kit and build in the larger midrange horn.
Previous Topic: Hi Wayne: Your Paramours and the new Studio 2?
Next Topic: My One Pi's are done (almost)
Current Time: Tue Oct 20 00:02:41 CDT 2026
