Home » Sponsored » Pi Speakers » Studio 2's and Subwoofer
Studio 2's and Subwoofer [message #45919] Mon, 29 November 2004 22:16 Go to next message
cavernicola is currently offline  cavernicola
I'm thinking about adding a subwoofer to go with the Studio 2's, since I'm "hitting them hard" at high volume with alot of bass. I was thinking something along the lines of the Dayton Quattro 10" subwoofer. I have just enough mdf left to build them in a ported cabinet as recommended here: Dayton Quattro Ported. It looks very interesting to me since its very small and can produce low bass at high spl's, and its cheap too! What would be a good frequency to cross over with the Studios in a small room (17' X 12'). I was thinking around 100 Hz. What about slopes? Should I go for a high (24 db Linkwitz) or medium (12 db/oct dec?) slope? Thanks in advance...
Re: Studio 2's and Subwoofer [message #45924 is a reply to message #45919] Tue, 30 November 2004 10:54 Go to previous message
Crossover between 60Hz and 100Hz. If you're planning to go with just one sub, I'd go with a high-order slope and use an amp that allows some adjustments. When you use a single sub, it is usually pretty far away from the mains so you'll want to have some ability to tailor it according to placement and room conditions. If you can go with two subs, I'd place them within a couple feet of your two π's and I'd use a first-order crossover. In that way, the transition will be seamless because with sound sources are within a 1/4 wavelength of each other.
Previous Topic: Wondering about the diff between $60 Alpha and $230 JBL in 8Pi?
Next Topic: FYI: Used JBL horns/drivers for sale
Current Time: Fri Nov 06 07:51:08 CST 2026
