Home » Sponsored » Pi Speakers » 2pi cabinet change ?
2pi cabinet change ? [message #45900] Sun, 28 November 2004 06:36 Go to next message
kupfer_m is currently offline  kupfer_m
Hi,
Does it hurt to change the dimensions of the 2pi and move the bassreflex-port to the back without changing the interal volume ?
I'd like to have a smaller but deeper cabinet.
Thanks,
Jim
Re: 2pi cabinet change ? [message #45901 is a reply to message #45900] Sun, 28 November 2004 12:22 Go to previous message
You can make the cabinet a little shorter and deeper if you want. Just keep the internal volume the same and it will be fine. Port placement is generally uncritical; Just be sure it is unobstracted and don't put the port entrance right near the midwoofer cone where midrange frequencies can enter easily. It's nice if the port faces a panel with insulation so that midrange frequency energies are attenuated.
Previous Topic: Very interesting article/experiments
Next Topic: Selenium 12co1P for center and rears to match my 7 PI's
Current Time: Sat Nov 28 20:44:33 CST 2026
