Home » Sponsored » Pi Speakers » How much power can my 4 pi premium take?
How much power can my 4 pi premium take? [message #45254] Tue, 24 August 2004 19:03 Go to next message
drguayo is currently offline  drguayo
I'm finally going to get to take these things out for a real drive. I will be using my 4 pi's as a PA for an event in a school gym. What can I safely run through them all day long? I'm thinking 750-1000 w/channel ?
thanks people.
craig.
Re: How much power can my 4 pi premium take? [message #45256 is a reply to message #45254] Tue, 24 August 2004 22:24 Go to previous messageGo to next message
They should be able to handle 1000 watts at the bottom end, no problem. Eminence rates them at 1250 watts RMS.
If you're pushing them hard, I'd limit amplifier output below 40Hz with a subsonic filter, if possible. Alternatively, just listen for bottoming out, which sounds like you'd expect, sharp impact sounds. It sounds sort of like detonation in an engine, an unusual clacking sound. Also, from about 1kHz up, the system can't handle more than about half that much power. But this probably will be no problem because of the distribution of sound in the spectrum. Watch for the light bulbs glowing, and that will tell you you're getting up there.
Are those the Premium Stage 4 Pis? [message #45260 is a reply to message #45254] Wed, 25 August 2004 10:10 Go to previous messageGo to next message
James W. Johnson is currently offline  James W. Johnson
Let us know how it works out for you.
Re: Are those the Premium Stage 4 Pis? [message #45262 is a reply to message #45260] Wed, 25 August 2004 11:45 Go to previous message
Yes: Premium Stage 4 Pi
Kilomax 15
PSD2002 -> Peavey CH3 horn
Previous Topic: Is Pi for me
Next Topic: Ping "Wayne Mark" !!!!
Current Time: Wed Oct 21 20:28:34 CDT 2026
