Home » Sponsored » Pi Speakers » woofers for sub horn
Re: Horn Design [message #45248 is a reply to message #45241] Sun, 22 August 2004 19:43 Go to previous messageGo to next message
Youl be looking at ~700litres ea then.
1x12" lab12 per horn ?
If you decide on a driver its easy if you fold the way i do.
The classic S style folding still works.That F3 40hz horn,has excursion minimum at 50hz(good for most music) and is 340litres :-)
Copy and Paste
http://www.geocities.com/basshornguy/40hzi.PNG
http://www.geocities.com/basshornguy/40hzl.PNG
Cheers!
Re: somebody say 24 hz horns [message #45249 is a reply to message #45243] Sun, 22 August 2004 21:19 Go to previous messageGo to next message
That's a really impressive horn and article. Thanks for posting it here. Do you suppose you could make higher resolution images available? I think I'll drop a link over at the High Efficiency forum.
24hz Design [message #45257 is a reply to message #45241] Tue, 24 August 2004 22:32 Go to previous message
-1x lab12 driver
-Throat 200cm^2
-Expo 6metre path
-Mouth 6000cm^2
-Rear chamber 55 litre
-Corner usage-
Low excursion point- 24hz,43hz.
100db/1watt @ 20hz 105db/1watt @ 50hz
100watt input 125db 50hz
100watt input 123db 23hz
with that 100watt input,excursion is great below 23hz,subsonic filter required.
I can cad it sometime if your interested.Probably just a big S folding.
Cheers!
Previous Topic: evil woofer
Next Topic: Is Pi for me
Current Time: Sun May 12 08:00:28 CDT 2024
