Home » Sponsored » Pi Speakers » Pi 8 question
Pi 8 question [message #45156] Wed, 04 August 2004 11:22 Go to next message
Barry is currently offline  Barry
Hi there and excuse the silly question:
Is is possible to turn the pi 8 into a corner horn by pointing the midhorn section (with the alpa 10) toward the corner while still using the horn tweeter pointing forward as do other corner horns in the Pi speaker line up.
If this worked without effecting the performance of the mid horn it might bring the bass up to a higher level?
Perhapes this would change sound of the mid horn?
Thanks in advance
Re: Pi 8 question [message #45158 is a reply to message #45156] Wed, 04 August 2004 11:27 Go to previous message
The eight π loudspeaker is already designed to take advantage of corner loading. While corner placement isn't required, the cabinet is shaped so that they fit well in corners and can take advantage of this arrangement.
Previous Topic: Pi 5 vs. Pi 8 questions for Wayne
Next Topic: Old style loudspeakers
Current Time: Fri Oct 23 03:05:49 CDT 2026
