Home » Sponsored » Pi Speakers » Thermionic 3Pi with midrange horn ?
Thermionic 3Pi with midrange horn ? [message #44728] Mon, 07 June 2004 13:34 Go to next message
kupfer_m is currently offline  kupfer_m
Hi,
A while ago I build the 3Pi's.
Now I was wondering if it would be a good idea
to add a midrange horn to this design (with an Eminence Alpha 6)
or just leave the design as is ?
Thanks in advance,
Jim
Re: Thermionic 3Pi with midrange horn ? [message #44729 is a reply to message #44728] Mon, 07 June 2004 13:44 Go to previous messageGo to next message
Personally, I'd leave them as-is.
Re: Thermionic 3Pi with midrange horn ? [message #44730 is a reply to message #44729] Thu, 10 June 2004 02:23 Go to previous messageGo to next message
Yury is currently offline  Yury
I'm afraid middle range is not acsentive as well.
Re: Thermionic 3Pi with midrange horn ? [message #44731 is a reply to message #44730] Thu, 10 June 2004 03:25 Go to previous messageGo to next message
Actually, I think the reason that Wayne would rather leave the 3Pi as-is is because that speaker is supposed to be a simple and low-cost solution that works well how it is.
Wayne's put togethor the 8Pi loudspeaker if one wants to use a midrange horn. Or use one with the Pi cornerhorns instead.....
Re: Thermionic 3Pi with midrange horn ? [message #44732 is a reply to message #44731] Thu, 10 June 2004 03:33 Go to previous messageGo to next message
I see. anyway DIY means to make thing better then other, or for special size or disign. I never heard any 2 way loudspeaker better 3 ways system or 2+1. let it be cheap, but voice range of waves must be a real.
Re: Thermionic 3Pi with midrange horn ? [message #44733 is a reply to message #44732] Thu, 10 June 2004 03:49 Go to previous messageGo to next message
The choice to go 3-way or 2-way really depends on what you're trying to do. There are pro's and con's either way. I have seen excellent implementations of both.
Wayne sells the 3Pi's as completed speakers hence his opinion to leave them as-is would be somewhat based around that I'd assume...
Re: Thermionic 3Pi with midrange horn ? [message #44734 is a reply to message #44733] Thu, 10 June 2004 04:20 Go to previous messageGo to next message
it's ok. thanks for comment.
Здравствуйте! [message #44735 is a reply to message #44734] Thu, 10 June 2004 07:51 Go to previous messageGo to next message
Здравствуйте Юрий!
Ваша колонка красивая. Класс!
Re: Thermionic 3Pi with midrange horn ? [message #44736 is a reply to message #44731] Thu, 10 June 2004 08:03 Go to previous messageGo to next message
You're exactly right. The midwoofer in this speaker is really a wide range driver and works very well through the midrange. I like the two-way configuration for speakers like these. This design makes use of a wide range midwoofer driver and eliminates a crossover point. For a three-way or four-way speaker, I'd rather use a woofer that's tuned low and optimized for use below the midrange band.
Re: Здравствуйте! [message #44737 is a reply to message #44735] Thu, 10 June 2004 11:11 Go to previous messageGo to previous message
can't read
Previous Topic: Seven Pi with Midhorn
Next Topic: Typical Room Gain?
Current Time: Sat May 04 17:15:52 CDT 2024
