Home » Sponsored » Pi Speakers » Midhorn/8pi
Midhorn/8pi [message #44585] Sat, 08 May 2004 14:51 Go to next message
Duncan McBride is currently offline  Duncan McBride
I'm building the cabinet to the 8pi. It will look like Wayne's drawing, about 36" by 24", and 16" deep. It will break halfway and narrow to 12" wide at the back. Here is a picture of the upper part from the side - I've sandwiched the horn between the top and a piece of ply the same dimensions as the top and bottom that will support the horn. I had to cut ports in the lower support to open the area behind the Alpha 10 to the cabinet below. The question is will the ports I've cut be large enough? Here is a link to the support. The area of the cutouts total about 115 square inches.
Re: Midhorn/8pi [message #44587 is a reply to message #44585] Sat, 08 May 2004 17:30 Go to previous messageGo to next message
Looks great!
I believe you'll have no problems with the cutouts and it should operate fine.
Re: Midhorn/8pi [message #44594 is a reply to message #44585] Sun, 09 May 2004 11:25 Go to previous message
It does look nice. Super work. I agree with Adrian, the area of your support cutouts is large and will be just fine.
Previous Topic: Holy Trigonometry!
Next Topic: what speaker for 2a3 tube amp?
Current Time: Mon Oct 26 07:26:28 CDT 2026
