Home » Sponsored » Pi Speakers » Eminence CD horns
Eminence CD horns [message #44385] Tue, 13 April 2004 16:11 Go to next message
Harald is currently offline  Harald
Hi Wayne,
You recommend either the JBL 2370A or Eminence H290 horn for the JBL 2426 or Eminence PSD2002 driver.
Is the Eminence SST1 or LT250 horn also suitable for these drivers?
Any pro's and con's on the Eminence CD horns?
I like the edged design of CD horns!
Thanks for sharing your experiences.
Harald
Re: Eminence CD horns [message #44389 is a reply to message #44385] Tue, 13 April 2004 17:58 Go to previous message
All Eminence horns (except the T12000) mount either the Eminence PSD2002 or JBL 2426 compression drivers. Almost all of my designs use the H290, but a few use the LT250. Naturally, dispersion is much narrower on the LT250.
I tend to prefer wider dispersion for home hifi use. Horns with 90o horizontal dispersion are perfect for cornerhorns, and usually sound great on freestanding designs as well.
Previous Topic: Do we have a pic of Grill Cover ona speaker? nm
Next Topic: "You want those JBL's to go?
Current Time: Fri Nov 06 02:14:20 CST 2026
