Home » Sponsored » Pi Speakers » Formula's
Formula's [message #43944] Fri, 13 February 2004 18:33 Go to next message
Does anyone have formula's to calculate the new value of Qts/Qms/Qes/Fs as you add more mass to the cone?
I have some formulas here, but they are dependant on each other, so it doesn't work right for this. As you can see:
Qms there relies on Rms as well, and to calculate Rms requires Qms. + I think Rms relies on Mms, as its related to Qms.
Any help highly appreciated!
Adrian
Got it [message #43947 is a reply to message #43944] Fri, 13 February 2004 23:49 Go to previous messageGo to next message
Don't worry about it, somebody has told me the formula's on another forum.
Adrian
Re: Formula's [message #43950 is a reply to message #43944] Sat, 14 February 2004 04:29 Go to previous message
Check out Claus Futtrup's Driver Parameter Calculator here and in the post called "obtaining driver parameters." Not only is his program useful for finding and maintaining a set of driver parameters, but the documentation included is exhaustive. You may find the documentation and formulas more useful than the program itself. Also, while it doesn't describe mechanical mass/spring parameters, Brian Davies' T/S article is a good reference when you're working in the T/S realm.
Previous Topic: Port Flare on 2 Pi
Next Topic: Question on Theater 3
Current Time: Thu Nov 05 18:35:34 CST 2026
