Home » Sponsored » Pi Speakers » Wood for Seven Pi Speakers?
Wood for Seven Pi Speakers? [message #43717] Mon, 19 January 2004 13:50 Go to next message
Dean Kukral is currently offline  Dean Kukral
Does anyone know offhand how many sheets of 5x5 baltic birch plywood it takes to build a Seven Pi kit? Same question for Seven Pi - 18? Does anybody have a CAD layout drawing for the pieces?
I can do all this myself, but I have grown lazy and do not want to reinvent this wheel.
Re: Wood for Seven Pi Speakers? [message #43718 is a reply to message #43717] Mon, 19 January 2004 14:49 Go to previous messageGo to next message
Hey lazy bones!
7pi 18Stage, 18Pro, 15Theater
4 sheets 4*8
6 sheets 5*5
7pi 15Stage, 15Pro
2 sheets 4*8
3 sheets 5*5
let me know whish one strikes your fancy
Thanks! [message #43719 is a reply to message #43718] Mon, 19 January 2004 15:06 Go to previous messageGo to next message
Thanks, Bill.
Re: Wood for Seven Pi Speakers? [message #43727 is a reply to message #43717] Tue, 20 January 2004 09:23 Go to previous message
Have you tried SheetLayout or CutList Plus? I've used SheetLayout.
You enter your pieces in a spreadsheet, enter your stock type, and
hit the Run button. It plots all your cuts and shows how many sheets
you'll need. You can pick grain direction, etc.
The low capacity version is free to use. For some simple things,
I've been able to do a slighter better (IMNSHO) job of
layout. For bigger jobs, I'm sure it would win hands down.
Chris
Previous Topic: foam horns and heavy drivers
Next Topic: Some Newbie Questions
Current Time: Sun Oct 18 13:29:44 CDT 2026
