Home » Sponsored » Pi Speakers » Modeling stage 7 pi
Modeling stage 7 pi [message #43641] Tue, 13 January 2004 11:01 Go to next message
dwkurfma is currently offline  dwkurfma
Hi Wayne,
Thought I saw this info once on the forum but now I can't find what I am looking for. I understand how you are using the corners of the room on the 7 pi stage as a simple conical flare, but I don't understand how you get the midrange high enough to use a PSD2002. Did you cover this on the forum or one of your papers? Can you tell me what S1, S2, and CON would be so I can see how this rascal looks in Hornresp?
Thanks!
Dan
Re: Modeling stage 7 pi [message #43647 is a reply to message #43641] Tue, 13 January 2004 15:56 Go to previous message
The sound coming from a π cornerhorn reverts from horn loading to direct radiation above about 300Hz. Beyond that point, the walls become reflectors instead of flare walls. So you can essentially forget about horn characteristics above 300Hz and view the system as a direct radiator facing a corner reflector.
Previous Topic: 2pi Tower Plans
Next Topic: Great Plains Audio Community Meeting - Pics
Current Time: Thu Nov 26 11:32:30 CST 2026
