Home » Sponsored » Pi Speakers » Why can't you use a single line array module on its own???
Why can't you use a single line array module on its own??? [message #43335] Thu, 11 December 2003 11:23 Go to next message
Jeremy Bridge is currently offline  Jeremy Bridge
I have seen posted over and over than line array modules only work in big numbers, (as a line array).
I understand that you need a large number of drivers to create a proper line array. But my question is why can you not simply use the induvidual module stand alone. Say two modules (1L, 1R) for say a small show, or maybe even 4 (2, 2R) to increase your vertical dispersion a little. I realize that you won't recieve the benifits of the line array anymore.
When the module is removed from the line would it not essentially become normal cabinet, only in a horizontal footprint?
Array Speakers Forum [message #43337 is a reply to message #43335] Thu, 11 December 2003 11:37 Go to previous message
You might want to post this on the Array Speakers forum.
Previous Topic: Hmmmm
Next Topic: Old Salvation Army speakers
Current Time: Fri Nov 27 05:02:56 CST 2026
