Home » Sponsored » Pi Speakers » Spec of Pi Speakers
Spec of Pi Speakers [message #43186] Mon, 24 November 2003 19:00 Go to next message
Gabriel is currently offline  Gabriel
I just want to know the frequency response spec. in Pi speaker web site, is that -3dB point or else?
Thank's
Re: Spec of Pi Speakers [message #43187 is a reply to message #43186] Mon, 24 November 2003 19:28 Go to previous message
A full set of data is provided for each component, showing response graphs and what-not. This should be considered the most definitive specification source. There is also a general description for each loudspeaker which shows prices and things like power handling and maximum output. These numbers aren't nearly as descriptive as the spec sheets for each component, but do give a general idea. For these, you should consider the power rating as a 70% point and the usable frequency range within +/-5dB a la Klipsch. Some are more conservative, some less.
Previous Topic: What can I make with this sub box?
Next Topic: 2 Pi tower questions
Current Time: Fri Oct 23 12:43:34 CDT 2026
