Home » Sponsored » Pi Speakers » box design/plans for JBL 2226
box design/plans for JBL 2226 [message #43089] Wed, 19 November 2003 07:44 Go to next message
Don17 is currently offline  Don17
Dear fellow audio enthusiasts,
I currently use a pair a dual 15" JBL Full range speakers that I built for my sound reinforcement system. I just bought a pair of JBL 2226's(4 Ohm version) to extend the frequency response of the system down to at least 35Hz. I want to make the most of the power I have to push them (750watts x 2 into 4 ohms stereo). I was thinking of a vented box of about 6 cubic feet tuned to 30Hz. But I guess I would need at least 1200 watts to get those monsters booming!!!! how about a folded horn?? Those tend to be efficient. Would that work for me?? Since designing horns are quite difficult, does any one know of a horn or vented box that will have those woofers thumping????
-Thanks alot
-Don
P.S. Answer Soon!!! JBL Rules!!!!
Re: box design/plans for JBL 2226 [message #43095 is a reply to message #43089] Wed, 19 November 2003 09:55 Go to previous messageGo to next message
Both the Professional Series seven π and the Professional Series ten π are horns that use the JBL 2226.
Re: box design/plans for JBL 2226 [message #43096 is a reply to message #43089] Wed, 19 November 2003 10:30 Go to previous messageGo to next message
Hi Don i bought a 2226H 2nd hand and have it blasting away on ten watts (later to be 240watt)
Wayne has his own good plans for it Pi style..
Caution,in an EBS tune like mine,175L 33hz tune,the power is limited,not 600watt rms ,i forget the actual value perhaps 300-400watt within Xmax..
I have modeled it in my own basshorn however the lab12woofer gave me what i wanted in a tiny box(its specificaly designed for horns)
The jbl2226h certainly is a beast at 97db efficiency also.See my response on my site,and see how i describe it :-)
Cheers
Mike.e
Re: box design/plans for JBL 2226 [message #43098 is a reply to message #43096] Wed, 19 November 2003 11:00 Go to previous messageGo to next message
Hey mike,
How about the 40Hz Horn on your site?? Seems fairly simple to build and looks like it would have a great kick. How about the plan below??? According to the designer, it can go down to about 50 hertz with excellent kick with the E140 (and I assume it might be able to go lower with the 2226) This Box seems extremely simple to build.... too simple for a folded horn. tell me what you think.
-Don
Re: box design/plans for JBL 2226 [message #43102 is a reply to message #43098] Wed, 19 November 2003 12:44 Go to previous messageGo to next message
Hey Don,
On the HD15 design, wouldn't waste my time for one thing the horn path length is to short to get down to 50hz, and Rog has a note on there to use at least 6 of them and use an 18" or 21" drivers for the sub frequencies. To get the 50hz out of them there just going to be acting like a sealed woofer cabinet anyway.
HTH
Bill W.
high 'kick' ,too simple. [message #43105 is a reply to message #43098] Wed, 19 November 2003 14:32 Go to previous messageGo to next message
toxicport.e is currently offline  toxicport.e
well that hort seems to be all 100hz.notice the VERY short path length!
50hz is -8db.
I plan on building my 1 or 2 versions 40hz basshorn over christmas if possible.
il tell you if its good.
Re: high 'kick' ,too simple. [message #43109 is a reply to message #43105] Wed, 19 November 2003 14:50 Go to previous messageGo to next message
Based on that graph, your 40Hz horn would be pretty nice sounding at the bottom of my PA stack. Since I see how you fold it, I'll try to get it to fit the 2226. Hopefully I should get a somewhat decent result.
Professional Series seven π and ten π speakers [message #43111 is a reply to message #43109] Wed, 19 November 2003 15:42 Go to previous messageGo to next message
Ten π's are a front-loaded horn designed to peak a bit at 40Hz, which really helps the 2226's nicely. Seven π's are simpler, and honestly, I prefer them when used in a home where corners are available. Certainly I'm biased, but I'd far prefer either of these two designs to a scoop, especially one that peaks at 100Hz.
Re: high 'kick' ,too simple. [message #43115 is a reply to message #43109] Wed, 19 November 2003 18:33 Go to previous messageGo to next message
the 2226 needs a large rear sealed chamber which rules it out of my maximally tiny horns..
The horn is directly optimised for that woofer.(the lab12)
waynes knows about this and has his own horns.
Hey Wayne, How Do I Get the plans?? [message #43116 is a reply to message #43095] Thu, 20 November 2003 04:03 Go to previous messageGo to previous message
Previous Topic: PSD 2002 For Sale
Next Topic: Woodfinishing experts...seeking advice
Current Time: Tue May 07 07:19:23 CDT 2024
