Home » Sponsored » Pi Speakers » Using Metal wall shelving brackets for bracing?
Using Metal wall shelving brackets for bracing? [message #42838] Thu, 30 October 2003 08:24 Go to next message
Have anyone tried using these wall shelving brackets for internal bracing of a speaker cabinet? They typically look like a hollowed out triangle. Seems a lot easier to use than cutting wooden cross braces. Would introducing metal components into the cabinet structure affect the speaker sound at all?
thanks,
gar.
Re: Using Metal wall shelving brackets for bracing? [message #42839 is a reply to message #42838] Thu, 30 October 2003 10:36 Go to previous message
Should be just fine. If it's solid - You'll know it. Give it a rap with your knuckles or a light tap from a hammer. If the cabinet gives a hollow drub-like sound or the metal rings, then you still have some damping work to do. But if it sounds solid, like you hit the Earth, then you've got it licked.
Previous Topic: A funny thing happened using PiAlign...
Next Topic: I've got some Yamaha C-drivers that look.......
Current Time: Sun Nov 22 22:25:07 CST 2026
