Home » Sponsored » Pi Speakers » A funny thing happened using PiAlign...
A funny thing happened using PiAlign... [message #42834] Wed, 29 October 2003 16:52 Go to next message
bikehorn is currently offline  bikehorn
so i input all the specs for the Celestion G18Q-400 because i want to make a nice cabinet for electric bass...and everything seemed nice until i looked at the depth measurement. i used a 0.75" wood thickness offset too. anyway, it says 14 inches. that doesn't seem right at all for a cabinet with an 18" driver...what could i have done wrong? try it yourself, see if you get something better.
the specs for the G18Q-400 are as follows:
D ­ 0.38m
Re ­ 6.4ohm
Fs ­ 32Hz
Qms ­ 7.06
Qts ­ 0.244
1/Qts - 4.09836
Qes ­ 0.252
Mmt ­ 99.2g
Cms ­ 0.25mm/N
Vas ­ 459l or 16.2094 Cu. Ft
Bl ­ 22.4Tm
Rms ­ 2.8kg/s
Re: A funny thing happened using PiAlign... [message #42835 is a reply to message #42834] Wed, 29 October 2003 17:23 Go to previous message
jlharden is currently offline  jlharden
Hi horn,
I came up with 28.46 H, 18.97W, 12.65D internal measurments with zero displacement added. 12.65 + 1.5 would make the depth about 14" external as you figured. Doesn't sound unreasonable to me. Let us know how they turn out! Jerrod
Previous Topic: Khorns in Harrisburg PA?
Next Topic: Using Metal wall shelving brackets for bracing?
Current Time: Sun Nov 22 22:05:39 CST 2026
