Home » Sponsored » Pi Speakers » Gauss Strength
Gauss Strength [message #42780] Thu, 23 October 2003 02:51 Go to next message
Hi all,
What does the gauss strength of the magnet represent on a driver? Is this something to do with good pro sound drivers, having high gauss strength? What does a higher gauss strength mean? Is there any relation to BL?
Thanks for any help!
Adrian
Re: Gauss Strength [message #42783 is a reply to message #42780] Thu, 23 October 2003 07:52 Go to previous messageGo to next message
Gauss is a measure of magnetic strength, or more specifically, of the magnetic flux at the measured point. It does not indicate mechanical force, and something must interact with the magnetic field to generate force. BL is a measure that includes the voice coil interaction, so it describes motor strength rather than just magnet strength.
Re: Gauss Strength [message #42785 is a reply to message #42780] Thu, 23 October 2003 08:01 Go to previous message
Adrian wrote,
:What does the gauss strength of the magnet represent on a driver?
The strength of the magnetic lines of flux.
:Is this something to do with good pro sound drivers,having high gauss strength?
Nope all speakers have gauss strength. Otherwise you have a de-magnitized magnet. The stronger the magnet the better the transient response, and correction from overshoot.(speed if you want to call it that.)
:What does a higher gauss strength mean?
A stronger magnet.
:Is there any relation to BL?
Yep, this is where the magnet and V.C. come into play.
HTH
Bill W.
Previous Topic: what drivers are in my Klipsch KLF-20's ? anyone?
Next Topic: A good link
Current Time: Fri Nov 06 01:40:40 CST 2026
