Home » Sponsored » Pi Speakers » Is there a disadvantage to having port diameter too LARGE?
Is there a disadvantage to having port diameter too LARGE? [message #42713] Wed, 15 October 2003 13:37 Go to next message
Tightwad is currently offline  Tightwad
Provided there is enough room in the enclosure for a larger (4" as opposed to 3") port, is there a disadvantage (assuming you tune to the same frequency)?
Re: Is there a disadvantage to having port diameter too LARGE? [message #42718 is a reply to message #42713] Wed, 15 October 2003 17:52 Go to previous messageGo to next message
There is no disadvantage to having large port diameter. It is a tunable parameter, and if it is set properly, the only disadvantages to large size are not acoustic, but are things such as mounting, ingres for small animals, etc.
Re: Is there a disadvantage to having port diameter too LARGE? [message #42751 is a reply to message #42718] Mon, 20 October 2003 16:38 Go to previous messageGo to next message
mikebake is currently offline  mikebake
I have found my cats inside my quad boxes AND the 2245 boxes a few times. YIKES! I face them together when not in use to avoid it!!! Horrors!!
Re: Is there a disadvantage to having port diameter too LARGE? [message #42769 is a reply to message #42751] Wed, 22 October 2003 13:07 Go to previous messageGo to next message
Don't you just blow them out with hi level, low freqencies, they move out pretty quick.
Re: Is there a disadvantage to having port diameter too LARGE? [message #42770 is a reply to message #42769] Wed, 22 October 2003 13:53 Go to previous message
No kidding, my one cat was 20 years old and deaf; she could feel the LF but it didn't bother her much into it cranked a good bit. The other cat would freak and come flying out right away. The deaf one could lay with its ear on the compression driver at 120db and sleep.
Previous Topic: JBL aftermarket kits
Next Topic: martinelli, how's the magenta?
Current Time: Fri Nov 06 01:10:35 CST 2026
