Home » Sponsored » Pi Speakers » Hi Guys! How about the ESG1 in a Theater 4?
Hi Guys! How about the ESG1 in a Theater 4? [message #42638] Wed, 08 October 2003 14:53 Go to next message
This ribbon tweet looks like a pretty good match to the Eminence Delta 15" in the Theater 4's. Anyone played with them?
G.
Re: Maybe so, maybe no [message #42639 is a reply to message #42638] Wed, 08 October 2003 15:59 Go to previous messageGo to next message
They are nearly perfectly flat, sweet sounding and detailed. And thats why I still like horns better. They are extreamly delicate in that a stray crossover below 1K with anything more than a a watt will stretch the ribbon. A pop from an amp will also do them in and you will have to repace the ribbon. Depending on what drivers your using and like you may or may not like the ribbon any better. If your looking for a change in scenery you shouldnt be dissapointed. IMO they cost too much. Consider the esg 2 or 3 for use with a higher crossover point.
best,
Bill
Re: Stay tuned, Garland, for..... [message #42641 is a reply to message #42639] Wed, 08 October 2003 16:19 Go to previous message
...the debut in my sorta 4 Pi Pro system of the "good" kraut drivers on Bill's woodhorns.
Have to build crossovers first and waitng for caps.
Creating is more like performing than listening
Previous Topic: crossover questions...
Next Topic: A bunch of questions
Current Time: Sun Nov 01 06:22:01 CST 2026
