Home » Sponsored » Pi Speakers » Brother, can you spare a few screws?
Brother, can you spare a few screws? [message #42633] Wed, 08 October 2003 14:11 Go to next message
Ubu is currently offline  Ubu
not that mine are loose or anything.........
I neglected to order some of the screws I need for my Pi Two's which are nearing completion. I haven't found them locally at Lowes or HD or the local hardware store. They are cheap and the mail order places have a minumim order.
So, anybody have 20 or so #8, 3/4" or 5/8", black, philips, pan head screws? I can send a few bucks and an SASE or will trade - I've 90 #6, 3/4", black pan heads........
pleeease, pretty please....
Ubu
Re: Brother, can you spare a few screws? [message #42636 is a reply to message #42633] Wed, 08 October 2003 14:29 Go to previous messageGo to next message
I used to always paint the heads black. Works just fine, but takes a few minutes to do.
But I keep about a thousand of those black #8 screws
Re:Why not use Numero 6? [message #42640 is a reply to message #42636] Wed, 08 October 2003 16:15 Go to previous messageGo to next message
As you will seef rom this most wonderful website, there is little difference in shank size:
Creating is more like performing than listening
Re:Why not use Numero 6? [message #42645 is a reply to message #42640] Wed, 08 October 2003 18:23 Go to previous messageGo to next message
Yeah, I actually have bins of about a thousand of both sizes. The difference isn't much, but some applications seem to prefer one to the other. The screw head of the larger one overlaps the gasket on some speakers, others it's just right.
Numero 6 heads too small [message #42648 is a reply to message #42640] Thu, 09 October 2003 05:14 Go to previous message
the #6 heads are too small for the alpha 10 holes - not a tight fit.
Previous Topic: A bunch of questions
Next Topic: Fostex FE 103 E full range driver and 8" alpha in PI folded horn
Current Time: Mon Oct 26 08:24:22 CDT 2026
