Home » Sponsored » Pi Speakers » Eminence Sensitivity Link
Eminence Sensitivity Link [message #42198] Sat, 16 August 2003 14:54 Go to next message
Here's an interesting link.
http://editweb.iglou.com/eminence/eminence/pages/resources02/sensitivity.htm
Re: Eminence Sensitivity Link [message #42199 is a reply to message #42198] Sat, 16 August 2003 16:27 Go to previous messageGo to next message
It's nice to see they are making up for years of mis-advertising the sensitivity specs on their drivers... Oh wait, they offset that but increased the power handling by 50%... :|
Adam
Re: Eminence Sensitivity Link [message #42257 is a reply to message #42199] Thu, 21 August 2003 23:18 Go to previous messageGo to next message
I dont know what Eminence has done in the past but that page just shows sensitivity with frequency. And with all speakers sensitivity will change over the entire audio range.
Re: Eminence Sensitivity Link [message #42261 is a reply to message #42257] Fri, 22 August 2003 07:43 Go to previous message
They use to advertise general specs. The Kappa 15LF used to be spec'd at 101db/1w/1m, which is quite deceiving. The new system is definitely a lot better.
Adam
Previous Topic: theater 3 plans
Next Topic: How do you tell when a horn "unloads"?
Current Time: Wed Nov 04 17:21:04 CST 2026
