Home » Sponsored » Pi Speakers » Box uning
Box uning [message #42136] Fri, 08 August 2003 07:22 Go to next message
ozzi is currently offline  ozzi
Please excuse the ignorance. When we say a box is tuned to a certain frequency, does that mean that is the lowest frequency it will reac.
If WinISD suggests a box tuned to 68Hz, what will happen to the speaker if the box is tuned to say 55Hz
Re: Box tuning [message #42138 is a reply to message #42136] Fri, 08 August 2003 13:02 Go to previous message
Try it and see. In some cases, this forms a shelved response and is commonly called an EBS alignment. In other cases, it creates an underdamped response, forming a small valley in response between peaks at fl and fh. See the different types of response you can expect in the post called "Response curves of closed vs. vented systems."
Previous Topic: pi one pro
Next Topic: woofer shorting rings
Current Time: Sun Oct 25 08:20:32 CDT 2026
