Home » Sponsored » Pi Speakers » Pi Subs
Pi Subs [message #41511] Thu, 29 May 2003 12:42 Go to next message
Wayne,
I guess I missed this also. If there is just one sub model, please send plans to cathouse7@sbcglobal.net, If several different models, please advise and I will request the correct one for my application.
Also, could you explain a little about the PiAlign software. The main problem is that I am a computer idiot-newbie. I downloaded the file, but when I opened it, there was a page of files. I attempted to open the first one out of curiosity, but that didn't work. I was looking for a tutorial but am obviously to stupid to find it. Can you advise? I have altec components I want to use with Pi horns. There is no better therapy than to demonstrate to the entire web surfing world exactley how lame my computer skills are!
Thanks for the help,
Russellc
You've got mail! [message #41513 is a reply to message #41511] Thu, 29 May 2003 15:22 Go to previous messageGo to next message
I've sent plans for the π subwoofer, which uses a powerful 18 inch woofer in a 10 cubic foot bass-reflex cabinet tuned to 30Hz. Suitable woofers include the JBL 2241, 2242, 2245 and the Eminence Omega 18 and Kilomax 18. It was originally designed for the JBL 2245 and Bill Martinelli is responsible for its looks. I think you'll agree that it is a very attractive design.
About the PiAlign program, there is some information in the "readme.txt" file contained in the distribution archive. That will tell you how to use the program and it will explain some of the terms used. I suggest that you create a directory on your computer called "PiAlign" and put the files in there. Then, you will run the "PiAlign.exe" program from that directory.
Re: You've got mail! [message #41523 is a reply to message #41513] Sat, 31 May 2003 10:49 Go to previous message
Thanks Wayne,
These plans are super!
Previous Topic: Audiophile series
Next Topic: Pi 500 Hz Xover for 515B/511B???
Current Time: Sat Oct 24 13:58:49 CDT 2026
