Home » Sponsored » Pi Speakers » Power Handling of Pi Crossover
Power Handling of Pi Crossover [message #41409] Sun, 18 May 2003 02:59 Go to next message
Hey Wayne.
I would like to know the power handling of the Pi Crossover. Will probably be purchasing the components for the xover tomorow :-)
Thanks!
Adrian
Re: Power Handling of Pi Crossover [message #41412 is a reply to message #41409] Sun, 18 May 2003 13:45 Go to previous message
Power handling is determined by the limits of the components used. Coils and resistors are rated in maximum current and capacitors in maximum voltage. So you can get whatever size you need.
Check the π crossover document for more information. Pages 67-80 are specifically about power handling, and illustrate the requirements of each component with voltage curves.
Previous Topic: Baffle spacing, phase angles and time alignment, revisited
Next Topic: Corner horn question
Current Time: Sun Oct 25 16:42:07 CDT 2026
