Home » Sponsored » Pi Speakers » 2 unit of Alpha 10" for corner horn & crossover question
2 unit of Alpha 10" for corner horn & crossover question [message #41293] Sun, 11 May 2003 10:34 Go to next message
Zeno is currently offline  Zeno
Hi Wayne,
I run the Pialign software today and found that I can use 2 Alpha 10" driver for a corner horn and the size of the enclosure is Ht 33.83, WD 16.9 & DP is 8.456. My question is if I would to use the psd 2002 eminence comp driver what crossover point should I be looking at.
Thanks.
Zeno
Re: 2 unit of Alpha 10" for corner horn & crossover answer [message #41296 is a reply to message #41293] Sun, 11 May 2003 12:13 Go to previous message
Hi Zeno!
Yes, I would expect the PSD2002 would work quite well in this arrangement. You really shouldn't crossover below 1.6kHz with this tweeter, but then again, there's no reason to consider going lower than that. The Alpha 10's work well an octave higher when used individually.
Wayne
Previous Topic: Two-way system
Next Topic: wayne Schematic for Pi 7 corner horn theater please
Current Time: Sat Oct 24 09:21:04 CDT 2026
