Home » Sponsored » Pi Speakers » Smaller corner horns
Smaller corner horns [message #41084] Sun, 20 April 2003 13:57 Go to next message
Thanks for the 7 plans, but I have noticed that the smallest dimension is the same as my front door opening! Could I have your 6 Pi plans for the 12" woofer? I saw some mention of a 5Pi 10" corner horn, but did not see it in the price list. Are the plans for the 10" Pi still available? If so, I would also be interested in these!
Thanks for your time (and plans)
Russellc
You've got mail! [message #41086 is a reply to message #41084] Sun, 20 April 2003 14:51 Go to previous messageGo to next message
Re: You've got mail! [message #41098 is a reply to message #41086] Mon, 21 April 2003 06:43 Go to previous messageGo to next message
Wayne
Perhaps the 7 pi is not as large as I thought. In the price list it shows dimensions as 56x32x48. Looking at the plans the seven Pi doesn't appear to be that wide. Are these 32" wide?
Thanks, Russellc
Re: You've got mail! [message #41101 is a reply to message #41098] Mon, 21 April 2003 08:02 Go to previous message
The 52x36x48 dimensions are for the Thermionic Series seven π speaker, which is the largerst in the line. The plans I sent you were for the Stage Series seven π, which is much smaller and uses a better motor.
Previous Topic: 4Pi-18 for bass amplification?
Next Topic: Motor subenclosure baffle cutout on 10Pi
Current Time: Sat Oct 31 16:11:02 CDT 2026
