Home » Sponsored » Pi Speakers » lastest project pics
lastest project pics [message #40575] Fri, 07 March 2003 15:04 Go to next message
Thanks to the dotcom daughter, here's a link. The tube active crossover is working great, with the one "glitch" that only ONE ic ground connection from the source is needed...use two and hum/buzz is there. Both channels work fine, just need one ground/shield wire "broken" on one ic. Discovered by accident, when I finally figured out why it would hum sometimes, and not other times while testing. At presnt, it is super unfinicky...you can pull the input cables with the amps running, and not generate a peep from them.
There is a shot of the smallest size you can reduce a regulated dc filament supply into...
And the "long wall" setup, consisting of the jbl4648a-8 bass bins and altec 902/511 horns, crossed 3rd order BW with the tube circuit at 800Hz. Phase aligned at 800Hz. Fortunately, the MC-240 input level controls allow for balancing/shelving the HF level with the LF adcom 555 amp. Source is CD variable output, DIRECT into the tube xover, then straight into the amps.
"Short wall" not shown is the same jbl/altec systems, but with 909 drivers, crossed at 800Hz. with the ss marchand XM9L unit feeding an adcom 545 (100watts/ch) and 535 (60watts).
Hard to believe a single tube stage could do the work of all those opamps in the XM9! But it does. Sam
Very Nice! [message #40577 is a reply to message #40575] Fri, 07 March 2003 18:53 Go to previous messageGo to next message
Robert Hamel is currently offline  Robert Hamel
Hello Sam
So how do you like that big bad set-up?? How are the 2404's on top?? Nice rack I just finished mine about a month ago. I bet it cooks! The clarity bi/triamping is really worth the effort.
Sweet McIntosh amp and 6DJ8 crossover! [message #40578 is a reply to message #40575] Fri, 07 March 2003 23:48 Go to previous messageGo to next message
Lookin' good!
I love your McIntosh amp and 6DJ8 crossover. Really great speakers too!
That is sweet! [message #40579 is a reply to message #40575] Sat, 08 March 2003 04:50 Go to previous messageGo to next message
Re: lastest project pics [message #40581 is a reply to message #40575] Sat, 08 March 2003 05:28 Go to previous message
spkrman57
Sam,
Killer system. What is the vintage speaker cabinet at the right in the pic with the 4648's and horns??? It almost looks like a Bozak cabinet, I have a few Bozak 502's and it looks similiar to them.
Cheers, Ron
Previous Topic: Source for JBL Pro Sound Drivers?
Next Topic: i'm offering fellow pi-mates 20% off
Current Time: Fri Oct 23 20:50:51 CDT 2026
