Home » Sponsored » Pi Speakers » How do I determine the inductance of a Woofer
How do I determine the inductance of a Woofer [message #40510] Tue, 04 March 2003 04:33 Go to next message
Larry Acklin is currently offline  Larry Acklin
If the specs are unknown? (8 ohm impedance)- they are 15" "full range" in Sunn/Fender cabinets- probably Eminence. I have a L&C meter at work, but I'm scared to hook up a speaker to the thing- I never have- and I wouldn't want to blow one up. Any home shop method with a sine wave and o'scope, perhaps?
So I can add the woofer compensation to the excellent 2 way 1600 Hz crossover. It makes the CD horns sound wonderful.
Thanks
Larry
"Speaker Workshop" [message #40515 is a reply to message #40510] Tue, 04 March 2003 12:08 Go to previous messageGo to next message
I'd suggest looking into the Speaker Workshop by Audia.
Re: "Speaker Workshop"- That'll work- thanks! (NT) [message #40532 is a reply to message #40515] Wed, 05 March 2003 07:30 Go to previous message
Previous Topic: I need the Kick to kick drums
Next Topic: double bass horn
Current Time: Thu Oct 15 08:13:57 CDT 2026
