Home » Sponsored » Pi Speakers » 2pi tower dimensions, using 3/4" mdf
2pi tower dimensions, using 3/4" mdf [message #40175] Thu, 06 February 2003 12:42 Go to next message
bsuhy is currently offline  bsuhy
Sorry, I have been doing a lot of reading in the forum, and I haven't seen this answered.
I can't find any 5/8 mdf to build my 2-pi towers from, so I am going to use 3/4" mdf.
Should I try to keep the internal volume the same ( I computed it to be 7755 cubic inches ) or should I make it larger? If larger, by how much?
Thanks..
Re: 2pi tower dimensions, using 3/4" mdf [message #40177 is a reply to message #40175] Thu, 06 February 2003 12:47 Go to previous message
With a cabinet volume this large, the difference of panel thickness on total displacement volume is pretty small. What's more important is that you cut the right size port.
Previous Topic: Wayne: Advice for EV LS12A drivers in Pi Alignment?
Next Topic: Compare Thermionic 3pi and tower 2pi
Current Time: Thu Nov 19 13:20:51 CST 2026
