Home » Sponsored » Pi Speakers » Help! 2 pi plans to big to print
Help! 2 pi plans to big to print [message #40046] Sat, 25 January 2003 19:27 Go to next message
dobanion is currently offline  dobanion
I have drivers on the way and want to start on the cabinets. I can't seem to reduce the size of the plans small enough to print. Can anyone help?
Thanks,
Dennis
Re: Help! 2 pi plans to big to print [message #40047 is a reply to message #40046] Sat, 25 January 2003 19:45 Go to previous messageGo to next message
Go fetch Adobe Photoshop trial version. Or if you have XP, Wordpad will resize by dragging the arrows at the edge of the page. If all else fails, I think I remember Bmar having a downsized version he sent to someone in your predicament a few weeks ago. In any case, the answer to this, like almost everything else, is in the archives.
Stick around, build some speakers, pretty soon you'll be telling the next guy to look in the archives.
Welcome to Pi World.
Paint programs [message #40048 is a reply to message #40046] Sat, 25 January 2003 22:50 Go to previous message
Hi Dennis!
Bill pointed you in a good direction; You might also consider the trial version of Paint Shop Pro for resizing, viewing and printing the plans. Your kits include a copy of the plans, but to get started now, you might try the links provided in this earlier post.
Take care!
Previous Topic: spice model for omega 15 pi 4
Next Topic: 2 pi plans
Current Time: Thu Nov 19 12:31:40 CST 2026
