Home » Sponsored » Pi Speakers » Pi Speaker Plans
Pi Speaker Plans [message #39989] Wed, 22 January 2003 00:36 Go to next message
jguzman21 is currently offline  jguzman21
Was wondering if anyone had the plans for the 2 Pi & one the corner horns 6 or 7 Pi? Even though my wife doesn't really care for your generosity I am very thankful :-)!!
Regards,
John
You've got mail! [message #39991 is a reply to message #39989] Wed, 22 January 2003 00:53 Go to previous messageGo to next message
I've sent plans for the two π Speakers, and I'll send you plans for sixes or sevens when you decide which ones you want. There are several different models, so please decide which suits your needs best and let me know.
Re: You've got mail! [message #39992 is a reply to message #39991] Wed, 22 January 2003 02:16 Go to previous messageGo to next message
Thanks Wayne!!! I truly appreciate it!! What are some the major design differences between the corner horn designs?
Regards,
John
Various "series" and their differences [message #39993 is a reply to message #39992] Wed, 22 January 2003 02:54 Go to previous message
The main differences are in the components chosen. Thermionic series use Eminence Alpha parts. Theater uses Delta, Stage uses Omega, Premium uses Kilomax and Professional Series uses JBL Professional Series components. If money is "no object," then go with Martinelli wood horns for tweeters too.
Previous Topic: Impedance curves for Eminence Woofers?
Next Topic: Taking the shout out of piezo tweeters
Current Time: Sat Nov 28 20:28:48 CST 2026
