Home » Sponsored » Pi Speakers » Resistor question Wayne?
Resistor question Wayne? [message #39814] Fri, 10 January 2003 04:54 Go to next message
Edwin is currently offline  Edwin
Hi Wayne,
Can I use a cheap 20 ohm 10 watts resistor in the 2Pis. I am using my Paramours now and would like to try if this has any effect on the sound. Thanks.
Edwin
Not Wayne, but.... [message #39822 is a reply to message #39814] Fri, 10 January 2003 08:52 Go to previous messageGo to next message
JLapaire is currently offline  JLapaire
Are you thinking of putting the 20 ohm across the piezo? If so, you can do a test by just putting it across the speaker terminals. It's the same thing, but you don't have to pull anything apart. Nominal impedance goes to ~5.7 ohms.
John
Get non-inductive resistors [message #39825 is a reply to message #39814] Fri, 10 January 2003 10:34 Go to previous messageGo to next message
Sure, you can use the inexpensive wirewound resistors, and you might not notice the difference between them and the more expensive non-inductive parts. But even the good stuff is only a couple bucks a piece, so I recommend you go ahead and spring for non-inductive resistors instead.
Re: Not Wayne, but.... [message #39839 is a reply to message #39822] Fri, 10 January 2003 15:16 Go to previous message
Hi John,
Thans John. I will just place it across the speaker termnals.
Edwin
Previous Topic: EV HP640
Next Topic: 2 Pi and imaging?
Current Time: Tue Nov 03 13:09:17 CST 2026
