Home » Sponsored » Pi Speakers » Cornerhorn away from corner
Cornerhorn away from corner [message #39749] Sun, 05 January 2003 21:31 Go to next message
Smrtislav is currently offline  Smrtislav
Hi,
what happens, if I take the cornerhorn out of the corner? I suppose, that then the corner/horn loading effect goes away, but i can still listen to such a speaker, right?
Thanks,
K.
Re: Cornerhorn away from corner [message #39750 is a reply to message #39749] Sun, 05 January 2003 21:57 Go to previous message
>> What happens, if I take the cornerhorn out of the corner?
You guessed it. The spatial relationship changes, and the woofer isn't radiating in eighth-space so its sensitivity goes down. The speaker and crossover were designed with this in mind, so bass will be reduced and midrange and treble will be louder if cornerhorns are not used in corners.
Previous Topic: 2-pi evaluation
Next Topic: 2 pi towers - wiring question
Current Time: Sun Oct 18 01:07:41 CDT 2026
