Home » Sponsored » Pi Speakers » Question for Wayne
Question for Wayne [message #39660] Tue, 31 December 2002 09:21 Go to next message
Hi Wayne and Happy End of '02,
In rewiring my Theater 4 crossover I broke off the lead to one .47uF cap in the compensation circuit and was wondering if I can get away with substituting a .39uF? Hate to go with out music for long.
Thanks and Happy New Year to all!
Garland
Answer for Garland [message #39661 is a reply to message #39660] Tue, 31 December 2002 09:57 Go to previous messageGo to next message
Yes, you can use a 0.39uF in place of the 0.47uF. The highs might be a little more subdued, but not much. You can always replace the 0.47uF capacitor later if you want.
Re: Question for Wayne [message #39676 is a reply to message #39660] Wed, 01 January 2003 13:01 Go to previous messageGo to next message
DRC is currently offline  DRC
What sorta .39/.47uf are you using? (you know where this is going. . . ;-)
Keep your ears and your mind open.
it's the Jensen .39uF coppers you lent me! [message #39684 is a reply to message #39676] Wed, 01 January 2003 16:55 Go to previous messageGo to next message
You know, half of what I build with these days seems to originate in Copeland!
G.
Re: it's the Jensen .39uF coppers you lent me! [message #39685 is a reply to message #39684] Wed, 01 January 2003 17:25 Go to previous messageGo to next message
Funny how that works . . .
What was the original spec for the injured cap: .47uf ?volts?
Re: it's the Jensen .39uF coppers you lent me! [message #39691 is a reply to message #39685] Thu, 02 January 2003 05:58 Go to previous message
.47uF @ 200V I think the spec. calls for. I was using an Audiocap Theta F&F @630V.
G.
Previous Topic: speaker cover
Next Topic: What wood for 2π towers?
Current Time: Mon Oct 19 22:44:43 CDT 2026
