Home » Sponsored » Pi Speakers » Edgar Salad Bowl Horns PSD2002 attachment method
Edgar Salad Bowl Horns PSD2002 attachment method [message #39325] Tue, 03 December 2002 19:26 Go to next message
BrianG is currently offline  BrianG
Gentlemen,
Is the PSD2002 a good match for the Edgar Salad Bowl horn? If yes, how is it attached?
Thanks,
Brian
Re: Edgar Salad Bowl Horns PSD2002 attachment method [message #39326 is a reply to message #39325] Tue, 03 December 2002 20:39 Go to previous messageGo to next message
Yes, Edgar "salad bowl" horns will work just fine with Eminence PSD2002 compression drivers. You'll use the standard bolt-on mounts with them.
Thanks (NT) [message #39343 is a reply to message #39326] Wed, 04 December 2002 14:49 Go to previous message
Previous Topic: Three way I Pi combo
Next Topic: Fermat
Current Time: Wed Nov 04 15:43:59 CST 2026
