Home » Sponsored » Pi Speakers » add on
add on [message #39276] Fri, 29 November 2002 09:33 Go to next message
Pilkar is currently offline  Pilkar
hello! i have a question... is there any problem if i add a second order filter for a tweeter to a Pi crossover? should i remove the capacitor on the compensation network and leave it without further modifications? can i use a similar l-pad as in the compensation network to damp the tweeter?
thats all.... but... i`ll be back!
thanks!
Pilkar
Re: add on [message #39277 is a reply to message #39276] Fri, 29 November 2002 11:52 Go to previous message
To tell the truth, I don't suggest adding a super-tweeter. The speakers are designed to provide constant directivity across a wide horizontal spread with a fairly tall vertical forward lobe. The vertical nulls are spaced out far enough they aren't a problem, outside the pattern of the tweeter. When adding a super-tweeter, all that goes out the window. There would be lots of bands of interference as a result.
Previous Topic: Q for Till E: "Silica" Sandpaper
Next Topic: Alpha 10
Current Time: Thu Nov 12 12:41:10 CST 2026
