Home » Sponsored » Pi Speakers » Q for Till E: "Silica" Sandpaper
Q for Till E: "Silica" Sandpaper [message #39262] Thu, 28 November 2002 07:11 Go to next message
I've been studying your last word on Tung oil post and have a question that will immediately betray my utter lack of experience in this. You mention 320 "silica" sandpaper, which you describe as grey and grainy with lubricant in it. I've been looking through various woodworking catalogs trying to figure out what this is. The only dark sandpaper I see is wet/dry paper, but there's no mention in the descriptions of lubricant (although it described as "silicon carbide"). Is this it?
My compliments on your beautiful work and great site and thanks for your extremely helpful posts, even if I do prefer Strauss' operas to "Till Eulenspiegel"!
Happy Thanksgiving!
Bob
Only 'cause your not a trombonist.... [message #39264 is a reply to message #39262] Thu, 28 November 2002 09:30 Go to previous messageGo to next message
Bulletin!!!!!
Hard to believe, but Till has nade an eror!!!!
Shuld have wroten stearated aluminum oxide.
Has a lubricant, stearate. in with the aluminum oxide particles.
Okay for finishing, do not use for sanding raw wood, don't want that stuff under the finish and AlOx particles are too uniform. Always use Garnet paper for raw wood.
Unfortunately Not . . . [message #39274 is a reply to message #39264] Fri, 29 November 2002 05:40 Go to previous message
Thanks. I won't tell.
Previous Topic: Happy Thanksgiving!
Next Topic: add on
Current Time: Fri Nov 27 10:05:27 CST 2026
