Home » Sponsored » Pi Speakers » sealing 2 pi towers
sealing 2 pi towers [message #39203] Mon, 25 November 2002 04:25 Go to next message
jeff g is currently offline  jeff g
do the woofer and tweeter need to be sealed along the front face of the speaker (e.g. silicon ...)?
Re: sealing 2 pi towers [message #39206 is a reply to message #39203] Mon, 25 November 2002 11:00 Go to previous message
Hi Jeff!
Yes, the speakers should be sealed. In many cases, no gasket sealer is necessary. But if you find an air leak, seal it with some form of sealant - Silicon or caulk will be just fine.
Take care!
Wayne
Previous Topic: new vs old kilomax
Next Topic: eminence md 1" driver
Current Time: Tue Oct 20 19:56:18 CDT 2026
